97 blazer tranny prob HELP
Old Dec 8, 2009 | 08:41 AM
Duncan97's Avatar
Duncan97 is on a distinguished road
Default 97 blazer tranny prob HELP
so yesterday i try and put blazer in reverse and i get nothing but revs up so i drive it around all and still never worked then i had a friend get under it and move linkage and it stated to work is that my problem or is it a bigger one
Old Dec 8, 2009 | 09:48 AM
If you were able to move the shift linkage and get reverse, then I would say your issue is with an out of adjustment shift linkage.
Old Dec 8, 2009 | 12:01 PM
Duncan97's Avatar
so i should fix that right caus ei have not did anything just moved it and it worked so is there a way to tighten it up
Old Dec 8, 2009 | 12:58 PM
You can adjust the shift cable.
CLICK HERE for a little pictorial of how to adjust the shift cable. The F-body has practically the same adjustment method.
Old Dec 8, 2009 | 01:12 PM
Duncan97's Avatar
ok thanks
LSpoweredStepside
Sep 30, 2013 09:22 PM
armymedic
Apr 12, 2011 06:07 PM
joeazevedoiii
Nov 2, 2010 11:41 PM
96greenxj
Jan 18, 2010 04:32 PM
JB97
Nov 29, 2007 11:07 PM
