97 Engine Removal
Old Apr 13, 2008 | 07:51 AM
nite_vison's Avatar
nite_vison is an unknown quantity at this point
Default 97 Engine Removal
Ok, started into this thing.
Engine is free hanging, except for tranny. tranny crossmember is down.
Bellhousing bolts out, and starter. Driveshaft disconnected.
Barely split the case, how can I get at the torque converter bolts? They seem to be in front. I've tried moving tranny/engine all around/screwdrivers for prying/ even used my air hammer a bit.
Help please!
Old Apr 13, 2008 | 09:06 AM
Default RE: 97 Engine Removal
If you have the aluminum oil pan with the full round bellhousing on the transmission, then the only way to get at the torque converter to flex plate bolts is through the starter hole.
Old Apr 13, 2008 | 09:38 AM
nite_vison's Avatar
Thanks. I wish haynes
woulda mentioned that.
I know its a tight space around the starter, any other tips to with this?
What's the easiest way to stop the engine?
A. crank bolt
B. Screwdriver on plate
C. hose blocking piston through spark plug hole
D other
Old Apr 13, 2008 | 01:32 PM
I would never do something through the spark plug hole.
I would pull out one of the rubber plugs in the very bottom of the transmission bellhousing and stick a pry bar up through there to stop it. Should make it relatively easy to do using both hands.
Old Apr 13, 2008 | 05:11 PM
nite_vison's Avatar
Your suggestion sounds good, but the rubber hose stops the piston from reaching the top, and stops the crank. I've done it before-different vehicle though
Old Apr 13, 2008 | 05:25 PM
Hanr3's Avatar
pry bar through the small hole in the bottom of the bellhousing to lock the flexplate in place is the quickest and easiest.
Find my thread on Tranny removal in teh Self-Help section. I cover it pretty well.
Old Apr 13, 2008 | 05:40 PM
Hanr3's Avatar
ORIGINAL: nite_vison
Sorry, didn't mean to edit your post. I changed it back and added my comments here.
and what do you plan on doing if a chunk of that rubber hose shears off in the chamber?
Old Apr 13, 2008 | 06:19 PM
nite_vison's Avatar
I was working with an old time mechanic, after about an hour off fighting with some torque converter bolts, he handed me a piece of hose, and told me that. It worked as my last resort.
But a piece breaking off, I guess I'd move to the rear end and kiss the truck good-bye...lol jk but ya know
R Deschamps
Nov 2, 2011 08:39 AM
dunontme
Dec 1, 2009 11:41 PM
Navy85
Mar 1, 2008 07:57 PM
blazernate1002
18
Feb 12, 2007 11:11 PM
Bill_m.
Aug 11, 2006 06:30 AM
