99 Blazer misfire
Old Apr 27, 2010 | 06:49 PM
ruralcarrier1's Avatar
ruralcarrier1 is on a distinguished road
Default 99 Blazer misfire
Hope someone can help, I have a 99 Blazer 4.3. When starting it up I have had #4 cylinder misfire a few times. It doesn't do it all the time (3 or 4 times now), just when it is cold out (Northern Indiana). When I start it up in the morning to warm up, it will misfire, but after warming up it will go away. I have replaced the wires, distributor cap and rotor. Just had a misfire this morning.
Also after the engine has warmed up, sometimes i will get a noise (sounds like ice in a glass) from the same area when pushing on the gas. I now have 154,000 miles on this engine. Appreciate any suggestions !!
Old Apr 27, 2010 | 08:30 PM
How do the plugs look?
Old Apr 27, 2010 | 10:00 PM
jeffkoski's Avatar
jeffkoski is on a distinguished road
Maybe a bad spray pattern on an injector if the plugs are new buy some lucas injector cleaner. cheap gas will gum your injectors
wires should be ok at idle on the miss
Last edited by swartlkk; Apr 28, 2010 at 06:18 AM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Old Apr 28, 2010 | 07:01 AM
Plugs were replaced too. I am going to pull all of them out again and see how they are firing.
I bought one of the big bottles of Lucas Injector Cleaner about a month ago and am 3/4 of the way through it. Think it could have anything to do with the vacuum hoses.
Last edited by swartlkk; Apr 28, 2010 at 07:13 AM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has yet to reply.
Old Apr 28, 2010 | 07:15 AM
My question about the plugs was in regards to their condition. If they were replaced, how did the old plugs look? A condition with a single cylinder can often be identified by inspecting (reading) the plugs.
How are you 3/4 the way through a bottle of injector cleaner over the course of a month? Didn't you just dump it into the tank?
I prefer Chevron Techron Fuel System Treatment Plus due to the added filming agents that clean and preserve the fuel level sending unit, but that lucas stuff does a decent job as well.
Old Apr 29, 2010 | 09:33 PM
jeffkoski's Avatar
Qt of lucas treats 100 gallons paid ten dollars at napa
rrk03300
Nov 15, 2012 10:29 PM
jmatt07
Dec 18, 2009 09:48 AM
cdonofrio13
Aug 10, 2008 07:06 AM
Mustgofaster
Jan 11, 2008 10:36 PM
gus
Apr 4, 2007 07:42 PM
