Advice regarding fuel please
Old Oct 24, 2021 | 06:38 PM
Lgarretto's Avatar
Lgarretto is on a distinguished road
Default Advice regarding fuel please
OK so I have a 99 blazer. Has a hard time starting, but runs like a top once it starts. Has to crank a lot. Checked the fuel pressure. Turning the key to on but not starting it hits 65psi then drops to zero. Takes about 3-4 seconds. While idling it sits at 55psi.doesnt seem to leak down. I read that it needs 60 at a minimum all the time. New pump I guess?
Thanks.
Old Oct 24, 2021 | 07:16 PM
GeorgeLG's Avatar
Read the fuel pressure test in the sticky. Next is fuel pressure at the fuel filter. That will cut your possibilities in half and tell you if the pump is the problem.
George
Old Oct 24, 2021 | 07:28 PM
Lgarretto's Avatar
I guess I missed that. I didn't see it. But will do. Thank you
Old Oct 24, 2021 | 11:57 PM
free2ryanh's Avatar
free2ryanh is on a distinguished road
It's either the fuel pressure regulator or the check valve in fuel pump
K9lover0865
Feb 7, 2017 12:00 PM
TexanS10
Jan 11, 2013 12:15 PM
uglyvw
Jan 21, 2012 10:05 AM
walleye seeker
Sep 1, 2010 09:52 PM
Sprocket
Mar 20, 2008 09:39 PM
