Transmission problems
Old Jul 23, 2019 | 08:08 PM
Kent Garn's Avatar
Kent Garn is on a distinguished road
Default Transmission problems
So I have a 2000 Chevy Blazer four-wheel drive 4.3 anyways I decided to change the transmission fluid and filter had some trouble with the filter got it in so I thought started to back off the ramps car go through the gears but not engage look it up find out did there's a possibility that I got the wrong filter went back part store. Another filter put it in now the Blazer well move in reverse just like normal and if I manually shift it it runs good but starting out and drive no power hardly moves at all before I buy the first and second shift solenoid and drop the paint again should I be looking in other areas first oh and the fuse isn't blown thanks for the help
Old Jul 27, 2019 | 01:52 PM
Could you repost this but with punctuation. It is hard to tell what your troubles are with the transmission.
Old Oct 25, 2021 | 04:02 PM
Nikfox's Avatar
Nikfox is on a distinguished road
Default Was a little hard to follow...I have the same problems tho!
Old Oct 25, 2021 | 05:05 PM
GeorgeLG's Avatar
That OP post wins the trophy for the most epic run on sentence in the history of the known universe.
Old Oct 25, 2021 | 09:03 PM
Not as old as other threads....
Edit: lol last time only was the day after this post too
Blzerfan
Jun 3, 2018 02:19 PM
lividtaco
Oct 1, 2016 08:00 AM
davtak
May 21, 2013 07:56 PM
lucas30
Oct 29, 2011 04:51 PM
old96blazer
Mar 6, 2009 06:22 AM
