Another 4WD Issue
Old Sep 13, 2008 | 10:31 AM
96jimmy4x4in's Avatar
96jimmy4x4in is an unknown quantity at this point
Default Another 4WD Issue
Heres my problem, i got a 96 jimmy with 154,000 on it. My Four Wheel Drive doesnt work as of now. I reset the computer using the procedure in the DIY Forum Section. I also jumped the ground to pin 13 and got a code 2 readout from the 4wd switch lights. It says its an encoder fault (transfer case motor). Where should I go from here. I checked the vaccum line to actuator and it seems well. It will not do anything on the go it just stays in 2wd. My service light isnt on, I am also hearing about a Transfer case switch that seems like a cheaper easy fix compared to the encoder motoy, Any Ideas would be greatly appreciated....
Old Sep 14, 2008 | 10:28 AM
raylo's Avatar
raylo is an unknown quantity at this point
Default RE: Another 4WD Issue
Replace the encoder motor.
Old Sep 14, 2008 | 09:22 PM
how much do u think thad cost >
Old Sep 15, 2008 | 11:06 AM
raylo's Avatar
Here is an example from Advance Auto. You might findit cheaper if you look around some.
http://www.partsamerica.com/productd...72&PTSet=A
Blazer-503
May 26, 2013 09:25 PM
grn97gtp
May 25, 2012 06:07 PM
AdamDeWitt
Feb 21, 2012 12:06 PM
extreme
Jan 5, 2010 07:29 AM
AnCuth123
Nov 7, 2009 04:16 PM
