another stuck in park.
Old Jan 28, 2011 | 03:12 AM
nismo_2005's Avatar
nismo_2005 is on a distinguished road
Default another stuck in park.
ok none of what i found with a search helped much it just eliminated a few things. more or less i shut the blazer off for a few minutes came back out it fired right up but would not come out of park. no blown fuses and im not sure how to check the brake switch. any help at all would be great thanks in advanced.
Old Jan 28, 2011 | 10:12 AM
nismo_2005's Avatar
one more update i did find one blow fuse it is stud #2 im not sure what it is for. would it cause my issue? I cant just go out and buy one to check cause i am stranded without a ride cause the blazer is stuck in park.
Old Jan 28, 2011 | 11:28 AM
nismo_2005's Avatar
Ok i figured it out. It was the shift interlock if you put the key in between run and acc the shifter works.
1997 red chevy blazer
Jan 21, 2014 04:41 PM
greg94
Apr 4, 2010 01:12 PM
mjd808
Feb 17, 2009 11:15 AM
rdhack
Apr 17, 2008 09:47 AM
joey4703
Mar 26, 2008 09:27 AM
