antifreez in the oil!!!
ok so there is antifreez in the oil which makes me think it is the head gasket?, what are the other possibilitys it may be besides a cracked block?, i was thinking of going to get a commpresion check?
please any thing helps, thanks ,chris
Crack in the block, Cylinder head gasket, Crack in the head. Actually I would try pressurizing the cooling system with a dye in it. Then remove spark plugs and see which cylinder (if any) has the dye. If the dye is present the it is either a cylinder head crack or a bad gasket. If it is just in the pan the you have a cracked block. For either the bad block of head I would get it magnifluxed to find out for sure before turning to new parts.
Hope this helps
Hope this helps
there is a possibility that your intake manifold gasket has failed, dumping coolant where it should not go.
Yep, forgot about that one. Thanks quik
ORIGINAL: quik1964
ORIGINAL: samuknow
I would bet on this one. This is very common.
ORIGINAL: quik1964
shooter2499
02-04-2008 09:23 PM
