any trans rebuilders here?? help..
Old Nov 22, 2008 | 02:17 PM
Dakota_Don's Avatar
Dakota_Don is an unknown quantity at this point
Default any trans rebuilders here?? help..
hi and thank you, I am working on a front pump from a 97 4L60E, when i seperated the front pump i found a check bal and capsule laying loose inside a cavity. If you look at the ATSG manual it is part number 237, There are 2 of them. The one that is out and damaged is the one next to the boost valve assembly, i have the ball assemble back in, but it doesnt seal very well.. I beleieve thisis for the TCC? if this doesnt seal very well what will happen?
[IMG]local://upfiles/10375/B3BC81C3F6C9469486176A1C7DFE53DC.jpg[/IMG]
[IMG]local://upfiles/10375/7D291BE176EF409EA168B640E13172FF.jpg[/IMG]
Old Nov 22, 2008 | 11:07 PM
CoolAirVw's Avatar
CoolAirVw is an unknown quantity at this point
Default RE: any trans rebuilders here?? help..
I cant answer your question. Seems like a no-brainer. If the checkball doesn't seal replace it.
How are you testing its sealing ability? Most circuits in auto transmissions have "some" amount of leakage built into the circuit.
I would just replace it. I've seen guys that will smack the ball into the seat to "re-seat" it to make it seal better. Make sure that you "stake" the capsule in to make sure it doesn't come out again.
Note: your a lucky one. Usually when these come out the rebuilder takes the pump apart so fast that the peice just falls out, and is lost so it goes back together with the capsule missing and then there is repeat failure.
Old Nov 23, 2008 | 12:01 PM
Dakota_Don's Avatar
thanks, i been looking for a new ball and capsule. I tried smacking it, and i did get it to seal better.. I compared it with the other ball and capsule using brake cleaner.. and well the sealed realy good but yhe other no so well.. if this was my trans i would go a head and slap it in.. I will have to call trans star i guess..
any way hopefully some else may chime in..
Old Nov 23, 2008 | 01:49 PM
Dakota_Don's Avatar
I was looking at the transstar-web site and on the exploded view (PDF file) they dont even show the capsule and ball,,
http://www.transtar1.com/catView.asp...strIDS=1,5,608
ksunday1
Nov 5, 2013 02:22 AM
racsan
Oct 14, 2011 10:07 AM
rcravincase
Jun 29, 2010 08:09 PM
johnwiseman
Lifting Tech
Nov 3, 2008 09:51 PM
