anything else i need for tranny rebuild
Old Mar 1, 2010 | 01:31 PM
9t54x4's Avatar
9t54x4 is on a distinguished road
Default anything else i need for tranny rebuild
hi new member, first post. searched engine & transmission forum but couldnt find the answer im lookin for or at least any answer. i have a 95 4x4 lt and im getting the 3rd and 4th clutches replaced, i wanted to know if there was anything else i needed to do while i was getting that done.it sounds like a good deal for $150 with ac delco parts.was also wondering could something be burnt since the fluid was black when i changed it.i just bought the blazer in january so tryin to fix the only problem it has. thanks in advance for any replies
Old Mar 1, 2010 | 01:32 PM
You might as well do a full rebuild if they are replacing the 3/4 clutch packs. I would definitely get 'the beast' sun shell to stave of problems there. But you might as well do a full rebuild if they are going through the labor of pulling the transmission and tearing it apart to get to those clutches.
Old Mar 1, 2010 | 01:46 PM
9t54x4's Avatar
im goin to pull and replace it ,ive been lookin at bowtie overdrives parts as far beefing up the trans.i also wanted a shift improver kit for firm shifts,could that be achieved through the trans computer.
Old Mar 1, 2010 | 02:09 PM
I would always prefer to have hard parts changing shift firmness than software.
Old Mar 1, 2010 | 02:20 PM
9t54x4's Avatar
what parts would u recommend for improving the shift instead of tweakin the computer
Old Mar 1, 2010 | 02:29 PM
Just get the Transgo Shift Improver kit for the 4L60E.
Old Mar 1, 2010 | 03:04 PM
9t54x4's Avatar
ok, i thought u were talkin bout parts like the sun shell,servo cover,modulator,etc... i also have a 700r4 ,can it be converted to a 4wd trans
Old Mar 1, 2010 | 03:25 PM
Well, that too. But the sun shell isn't going to change shift firmness/timing. Apply pistons, etc can be done at the same time as well, but that comes down to what you want out of the transmission. The possibilities are extensive if you really want to drop some $$ into the trans. A general rebuild with a shift improver kit will make a nice reliable transmission.
Concerning changing a 700R4/4L60/4L60E from 2wd to 4wd or vice versa, it can be done, but it requires the complete gutting of the transmission to swap out the tail shaft with the appropriate length on (4wd is quite a bit shorter than 2wd).
Old Mar 1, 2010 | 03:52 PM
9t54x4's Avatar
well swappin is out the question for the 700r4 im not goin through that. ill just keep the 4l60e i know it 1/2 way works ,it fits, ill just put the shift kit in myself to save some loot. ijust want a tranny thatll be good on the trail when i take it out
Old Mar 1, 2010 | 04:06 PM
9t54x4's Avatar
thanks for the info ,im not swappin ill just install the shift kit myself mabe even paint it
Fullsizeon38s
Jan 26, 2013 09:50 AM
Blue thunder 2000
Aug 20, 2012 10:45 PM
rdlyn
Engine & Internal
May 7, 2010 05:23 AM
lizardqing
Nov 21, 2009 03:30 PM
Taymacjack
Engine & Internal
Aug 28, 2007 07:58 PM
