Anything Else To Change While I Do The Tranny?
Old Nov 21, 2009 | 02:39 PM
lizardqing's Avatar
lizardqing is an unknown quantity at this point
Default Anything Else To Change While I Do The Tranny?
Going to be swapping the tranny out in my 96 4x4 with 140k on it next weekend and all ready figure on swapping the rear main seal since it will be easy to get to. Is there anything else I should change while it might be conventional while the tranny is out of the way? The one that is going in is a used one with 22k on it. Thanks.
Old Nov 21, 2009 | 03:30 PM
tazz9690's Avatar
tazz9690 is on a distinguished road
you might as well do the u-joints since you are going to have the drive shaft out. If you haven't done them before and they have the original 140K, it's just good measure and do a diff. service while you're at it too.
Fullsizeon38s
Jan 26, 2013 09:50 AM
Blue thunder 2000
Aug 20, 2012 10:45 PM
rdlyn
Engine & Internal
May 7, 2010 05:23 AM
9t54x4
Mar 1, 2010 04:06 PM
Taymacjack
Engine & Internal
Aug 28, 2007 07:58 PM
