Auto 4x4
Old Nov 29, 2010 | 04:15 PM
myprixxx's Avatar
myprixxx is on a distinguished road
Default Auto 4x4
I was curious as to whether or not it was possible to add the Auto 4x4 to a blazer not originally equipped with it. If I were to get the 4 button switch what else would I need? Maybe a transfer case and the pcm? is the wiring there on the harness in the vehicle and to the tx case? or is this completely impossible?
Old Nov 29, 2010 | 05:13 PM
Red 96''s Avatar
I'm not 100% on this, but I'm pretty sure the transfer cases are different on the selectable 4 wheel drive equipped Blazers and the AWD Bravadas.
Old Nov 29, 2010 | 06:18 PM
myprixxx's Avatar
Yeah I had assumed they were, but I didnt know if there was more than that. Like does it still bolt up like my factory tx case without the A4WD? and would the wiring still be there or is that all different?
Old Nov 29, 2010 | 08:51 PM
Transfer case, TCCM, switch, wiring, programming, vacuum lines, electric vacuum switch, and the front driveshaft from what I remember. Could be missing some things, but overall, it isn't worth it.
Old Nov 30, 2010 | 11:52 AM
myprixxx's Avatar
definateley not. Will my normal e button 4WD work the same if I have a 4 button switch in there? the lights on mine are out, and I have the A4WD switch from my old blazer and I know all the backlighting works in that
Old Nov 30, 2010 | 12:10 PM
No, you cannot control the NV233 TCCM with a switch from an NV236 (4-button Auto4wd). The NV236 switch operates by using various resistors which the TCCM interprets via a voltage drop while the NV233 switch is a simple momentary switch for each button.
Old Nov 30, 2010 | 12:11 PM
robertr728's Avatar
robertr728 is on a distinguished road
Just replace the light bulbs. Its easy to do.
Old Nov 30, 2010 | 02:03 PM
myprixxx's Avatar
^^ any write up on this anywhere? I know in my pontiac most of those little bulbs are hard to find and have to be soldered in
Old Nov 30, 2010 | 06:33 PM
Flyfishen's Avatar
Flyfishen is on a distinguished road
All I can say is that Auto-4X4 switch is an excellent feature that I use often out here in Calgary Alberta Canada during the winter. It works very well out here and has saved my *** more than once.
Old Nov 30, 2010 | 06:42 PM
It is nice when it works, but there is more that can go wrong in the NV236 transfer case than in the NV233.
madmack4
May 24, 2012 12:59 PM
Tinted
35
Feb 7, 2011 01:12 PM
LannyL81
Aug 8, 2010 01:01 PM
ginobass
Sep 11, 2006 05:16 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
