bad knock in 97 blazer
i got a 97 blazer lt 4x4 for 700 bucks cosmetically its in great shape but it has a knock i found a 96 blazer motor its a 4.3 also i was wondering if it would swap in? if so how hard and how much time would it take to do the swap i have a friend who is helping since ive never done this before but hes a grad from college for auto mechanics
Should work you might have to swap intake manifolds if there different. I would pull it anyways to replace the gasket since it probably leaks like most do. Should take 2 days of solid work to get it all swapped and running . That depends on your talent and your tools you have available too.
The engines should be practically identical. If the drivetrains are different (2wd/4wd), then you will want to swap the oil pans, but that's about it. Just look things over closely when they are both out in the open.
helo
Dec 24, 2010 08:03 AM
yazan84
Mar 10, 2008 06:53 PM
