Bad Lifter?
Old Oct 25, 2009 | 10:21 PM
blueboy's Avatar
blueboy is on a distinguished road
Default Bad Lifter?
I am new here and have a problem with my 96.
I was wondering if a bad lifter would cause that engine bank to run rich?
The full story is: my 96 has a bad misfire on cylinder 4, has a constant lifter peck on cylinder 4, definite valvetrain noise, and bank 2 has showed up as running rich several times on my ses light. I took it to a mechanic and he thought it was a fuel injector, but the plug looks like all the others. He did say the compression in that cylinder was 20 psi lower than the others.(110~130) and tended to build up more slowly. It possesses no symptoms of bad rings and passed the vacuum test easily. I feel pretty confident that i have narrowed it down to a bad lifter or bad fuel injector, which is why i was wondering if a bad lifter would cause these symptoms because the mechanic said he didnt think it would and that 4.3s were famous for lifter noise.
Thanks very much for any help!
Old Oct 25, 2009 | 11:01 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
yes a bad lifter or cam lobe will cause a misfire have you checked to make sure the valve adjustment/tightness is correct?
Old Oct 26, 2009 | 12:00 PM
blueboy's Avatar
Would a bad lifter(or improper valve clearance like you said) also cause that engine bank to show up rich(by 'rich' i mean it showed code p0175, which doesn't necessarily mean its running rich, but at least theres not enough oxygen in the exhaust)?
I have not checked the valve adjustment yet, but i can put a rod against that valve cover and a large vibration can be felt with each peck of the lifter, if that helps determine anything.
Also, would any of those problems show up in the compression?
mudnsno
Nov 15, 2009 05:38 PM
jcoop711
Aug 27, 2007 12:42 PM
Chevyguy032
Nov 26, 2006 04:26 PM
Bob E.
Mar 31, 2006 11:39 AM
glenmoore670
Feb 15, 2006 11:08 PM
