Bent exhaust valve 4.3, why?
haven't pulled any other valves out yet. i'll do that today and really get a close look. thanks . i just saw that little chunk missing at the edge, where the valve seats. injury looks a little old though. we'll see
pulled one good exhaust valve, guides look the same, don't think piece chipped / broke off there. noticed intake side of cylinder lighter in color than 2 good cylinders. looked at intake manifold and injectors. pictures show difference. bad cylinder is lighter/ much more carbon buildup. colud this have happened after valve bent ? don't think so , but i'm not a mechanic, engine was run maybe 30 minutes with bent valve (son's house to mine, buddy said bring it over, he'll fix it (he didn't) please take a look
Pictures by kmulholl - Photobucket
Does the piston have marks on it?
If the exhaust valve wasn't closing, the cylinder wouldn't be able to properly pull fresh air in. That could be the reason for the different color in the runner. Another reason could be a lack of EGR gases making it into that cylinder as it is the rear most runner in the intake manifold.
thanks swartlkk, i don't drive the blazer, jay does. i don't know how it was running before it ended up on side of road. compression could have been low on that cylinder before and just got way worse (zero). what about the carbon on that injector ? did you see the photo ? seems to be very different.
89Recon
10-22-2011 05:50 PM
IndianaBlazerGirl
09-06-2011 06:22 PM
kmulholl
03-23-2011 12:25 PM
bigdaddykane93
12-16-2010 04:28 PM
