The best ATF. What's your pick?
Old Feb 22, 2010 | 09:13 PM
TomSawyer's Avatar
TomSawyer is on a distinguished road
Default The best ATF. What's your pick?
I'm about to be rebuilding my 700r4 transmission. What transmission fluids are considered to be top dog, both conventional and synthetic? (price also being a factor.) What's your pick and why?
Old Feb 22, 2010 | 09:28 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
Heard a lot of good things about Synthetic Royal Purple, but have never used their ATF. When i use their Engine oil i see a 10 PSI boost in oil pressure. if it were me i would use it. it runs about $10-12 a quart.
For Conventional i would say dexron 3 but the new dexron 6 is suppose to be better and fully compatible with dexron 3 trannys, but im not sure if its synthetic or conventional. about $5-8 a quart.
"DEXRON-VI was introduced in 2005. It was designed to replace all prior specifications, and is therefore backward-compatible with applications calling for DEXRON of any type. The specification defines both a performance level and specific additives that provide improved shift feel, friction durability and oxidative stability compared to earlier specified fluids."
Old Feb 22, 2010 | 09:32 PM
Dexron VI!
Old Feb 22, 2010 | 09:34 PM
rriddle3's Avatar
Since GM's latest ATF standard, Dexron VI, is a synthetic and fully backward compatible with transmissions designed for previous versions of Dexron, I woud use it.
Old Feb 22, 2010 | 09:39 PM
so dexron 6 is fully synthetic?
Old Feb 22, 2010 | 09:55 PM
TomSawyer's Avatar
Yes. A buddy of mine suggested VI as well. Any particular brand though?
Old Feb 22, 2010 | 09:59 PM
Considering that it hasn't been a long enough length of time for GM to release the full formula, I'm going to say GM. That is what I will be using come spring when I service the transmission on my Rainier (and install a shift kit + servos, etc).
Everyone else that has Dexron VI fluid is just guessing at it formulation and stating that it is compatible based on the specifications of the fluid.
Old Feb 25, 2010 | 11:48 AM
chrisf719's Avatar
chrisf719 is on a distinguished road
I bought the Castrol High Mileage ATF as my Blazer has 165xxx miles on it. What are your guys take on that?
Old Feb 25, 2010 | 05:55 PM
TomSawyer's Avatar
I like Castrol products but it sounds like GM Dexron VI is the way to go.
Guy2dogs
Performance & Brainstorming
Jul 29, 2014 04:59 PM
rexazz2
Sep 18, 2013 03:46 PM
BlazinJay84
Jan 25, 2008 07:50 AM
vassago41301
Jan 26, 2007 03:58 AM
acarlson
Jul 19, 2006 01:09 AM
