Best way to pull a 4.3
Old Jul 2, 2011 | 07:49 PM
lt1/ta's Avatar
lt1/ta is on a distinguished road
Default Best way to pull a 4.3
Hi Guys,
I was wanting to know how do you pull your motor and how long did it take you to do it.
I recently replaced mine (97 4wd)and I lifted up the motor and pulled the motor mounts off on the motor side,then dropped the motor down and it gave me more room to remove the top four transmission bolts and I also removed the steering shaft for more clearance.It took me 2 hours and 15 minutes to have the motor on the ground.
Thanks for any input guys.
Old Jul 3, 2011 | 09:22 PM
chris015's Avatar
thats about the best way to do it right there. Takes me about 4 hours since its ONLY me and no air tools. I need new friends that like cars.
Old Jul 5, 2011 | 10:14 PM
harrymonkeyboy's Avatar
harrymonkeyboy is on a distinguished road
i cant believe i didnt go that route i found some info here and in the s10 forum and read the only good way was to raise the body to not only access the top tranny bolts and to gain clearance to remove the motor and i did just that, with a friend the whole removal including raising the body only took a half day and that was with numerous smoke breaks, do you ever have any issues with clearance pulling the motor from its compartment fan off and radiator out ofcourse having not raised the body? or is is not an issue for you with yours being a 91' (that is the older body style right?) because mines a 2000
Old Jul 6, 2011 | 02:27 AM
chris015's Avatar
I always removed the radiator and whole front end(grill,etc) and slide it out the front trans and all. Much easier when you are by yourself.
Ive heard about the body raising. But unless you have some airtools ive done a few body lifts on some older s10 trucks and some of those body mounts WONT budge without some major air working.
Blazers.B.Kewl
Apr 22, 2013 10:06 AM
KevT
Sep 8, 2012 02:05 PM
JLaw
Suspension Tech
Mar 2, 2007 07:21 AM
ridin_low07
Jun 26, 2006 03:55 AM
ggwash21
Engine & Internal
Jun 17, 2006 02:08 AM
