blazer woes...
Old Apr 8, 2017 | 11:51 AM
bajjer9's Avatar
bajjer9 is on a distinguished road
Default blazer woes...
So my 96 blazer blew an intake gasket and water filled the engine. It sat for quite sometime before I got around to cleaning it up. long story short, it wont start. Here are some of what I did after cleaning the crap out of the engine
1)Checked spark at the #1 plug
2)installed the distributer pointing to the little notch with the 6 on it while engine was TDC #1 cylinder ( that is with the second timing mark on the balanced at the upper mark on the engine )
3)Manually applied 12v to each fuel injector (I upgraded the spider injection to the newer individually activated injectors) to confirm the solenoid works
4)The fuel pump is running and getting pressure (I can press the fuel pressure point and fuel comes out
5)New plugs
6)New cap & rotor
now I know Fuel+timing+spark=start but all it will do is act like its out of time and pop through the throttle body once in a while while cranking
Can anyone give me a push in the right direction? I know I am missing something
Thank ahead of time
Old Apr 8, 2017 | 11:21 PM
jck1961's Avatar
jck1961 is an unknown quantity at this point
Is it possible that you were at tdc on exhaust stroke and not compression stroke? The crank rotates 2x the camshaft, so the timing marks will line up at tdc on both compression and exhaust strokes.
You must be on compression stroke or your timing is 180 degrees off.
Old Apr 9, 2017 | 08:31 AM
bajjer9's Avatar
I dont believe so, I had a compression gauge in number1 and saw the pressure build up
datmanj
Feb 5, 2013 12:18 PM
tooth_dr
Nov 21, 2012 03:54 AM
waynec
Feb 12, 2012 04:36 PM
Rubbed Radish
Dec 28, 2011 03:22 PM
robert8868
Aug 18, 2006 12:22 PM
