Blazer wont start....FML!
Old Feb 8, 2012 | 02:24 AM
choover82's Avatar
choover82 is on a distinguished road
Any suggestions? Thanks =)
Old Feb 8, 2012 | 02:59 PM
xgiovannix12's Avatar
non of the above
you should buy delco or msd but i dont know how these engines react to msd
Old Feb 10, 2012 | 01:04 AM
choover82's Avatar
Decided not to give up the blazer. If its the ecu, its only $130 new...and someone offered me $200....bleh....no thanks....
Old Feb 10, 2012 | 06:47 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Its probably the ignition control module under the distributor cap , you can have it tested but I have seen them test ok and still be bad .
Old Feb 12, 2012 | 12:26 AM
choover82's Avatar
ive been told its the computer itself...so not sure who is correct.
Old Feb 12, 2012 | 01:56 PM
serrasalmus's Avatar
serrasalmus is on a distinguished road
mine was doing the same thing for months couldnt figure it out took it to a shop and they had it 3 weeks and it finally did it to them was the pick up coil and icm
Old Feb 13, 2012 | 03:55 AM
choover82's Avatar
dang...ive already got the ecu out..and now two people say its the icm...where is this at on the vehicle?
Old Feb 13, 2012 | 02:33 PM
the icm is located under the distributor cap and rotor
and it should look something like this
if its bad make sure you replace it with delco
Old Feb 13, 2012 | 11:15 PM
choover82's Avatar
ok. got it ordered, along with a new cap and rotor. wanted to work on that before work, but my sister took the car keys and left the car at home...GRRRR....
So, once the snow stops falling, i need to put the computer back in place, and re-attach the ignition coil and then tear into the dizzy.
Thanks for all the help guys, id be VERY LOST without yall!
Oh, and in the pic above...it looks like it slides into place...how do i remove and install?
JimmyBlaze541
May 2, 2013 10:00 AM
TheTransporter
Jan 24, 2011 06:44 PM
matt92
Sep 21, 2010 01:18 PM
1994BlazerS10
Dec 28, 2009 01:59 AM
Shotgunn99
Street N Strip
Nov 17, 2009 10:38 PM
