Blue smoke
Old Oct 6, 2008 | 07:02 PM
speakerwire's Avatar
speakerwire is an unknown quantity at this point
Default Blue smoke
1993 Tahoe V6
I just bought this Blazer so I don't really know what is going on with it.
I checked the compression and had About 150 lbs per cylinder all within 10 lbs of each other.
I have to keep adding coolant every 100 miles or so . I think that the heater core is leaking .
The oil is black and dirty with no signs of water , no rust on dipstick either.
I was leaning towards valve stem seals .
the blazer smokes at stop signs and as it being driven .
I just drove it 800 miles and used very little oil no more than two quarts .
Old Oct 6, 2008 | 07:41 PM
myol blue4x4's Avatar
myol blue4x4 is an unknown quantity at this point
Default RE: Blue smoke
The blue smoke is a sign of oil burning, and the oil being dark black could be because of sludge.
Old Oct 6, 2008 | 07:43 PM
gscrippler's Avatar
gscrippler is an unknown quantity at this point
If the heater core is leaking, you will (A)smell antifreeze inside the cab (B) the pass side carpet
might be wet (C) Inside windsheild Foggs.
As far as blue smoke, try checking oil level first, is it overfilled?
Old Oct 6, 2008 | 09:06 PM
fondo's Avatar
fondo has a little shameless behavior in the past
It is probably your lower intake manifold gaskets, that's one of the flaws associated with this motor. Easy enough to replace. just time consuming (8-12 hrs.) depending on your mechanical ability. Try the search feature, this topic has been covered many x's over. As far as needing to add 2 qts. of oil in 800 miles, I would say that is a bit much, but not far from ordinary. Search is your friend.
Old Oct 7, 2008 | 07:21 PM
Today I removed all the spark plugs and checked them for fouling.
All the plugs were in top shape as far as coloring.
They were cleaned 800 miles ago. All were dry and no signs of oil on the electrode or ceramic insulator just a little on the threads.
GScrippler
"As far as blue smoke, try checking oil level first, is it overfilled"
I have been keeping the oil topped on the dip stick.
I will let the level fall a little to see if the smoking stops.
I do keep a close eye on the oil and coolant.
It does smoke a little on start up.
I have been keepin the oil level at the top ma
medea1993
Jun 7, 2012 12:29 PM
LinuxWindows
Apr 15, 2012 11:33 AM
hondacharger
Jun 14, 2010 01:47 PM
bodhifirestarr
Mar 28, 2009 04:27 PM
scottty56
Dec 30, 2006 04:10 PM
