Can you run without the front drive shaft? 1998 4x4
Old 08-25-2008 | 08:51 AM
watsonracingteam's Avatar
watsonracingteam is an unknown quantity at this point
Default Can you run without the front drive shaft? 1998 4x4
My brother had removed it a month or so ago now I have some odd noise on start up coming from the front dif.
If it sits and idles I do not get it, but if I drive it right away it sounds like gears are trying to line up, they do after a few seconds then no more noise.
It would need to sit a bit, say 3 - 4 hours before it does it again.
ANY IDEAS?
Brian
Old 08-27-2008 | 11:14 PM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
Default RE: Can you run without the front drive shaft? 1998 4x4
mine is gone and no problesm ever??
Blade_24k
02-26-2014 04:03 PM
bertrenolds
03-08-2012 10:17 AM
brudel1
04-04-2011 01:00 PM
jorg
01-28-2011 06:02 PM
lizzj70
06-23-2010 07:57 PM
