Cat Converter Problem
Old Aug 5, 2007 | 04:58 PM
Shizer's Avatar
Shizer is an unknown quantity at this point
Default Cat Converter Problem
I started my blazer up the other day after I went muddin a few weeks back and after it idled down it started to putter a bit, idle up a bit and putter again. I went under the truck and listened to the cat and heard some rattleing inside. Im thinking of cutting it off. Any ideas? Maybe repair it or something instead of going with out? Also anyone know if you can get it legal after cutting it off in West Virginia?
Old Aug 5, 2007 | 06:18 PM
rriddle3's Avatar
Default RE: Cat Converter Problem
Sounds like a classic case of the cat's insides burning out and coming apart. They will make their way back to the muffler and start to plug it, also.The catshould be replaced since it is against Federal rules to remove a cat without replacement.
Old Aug 5, 2007 | 07:47 PM
Shizer's Avatar
Ah I see, good thing My pipes cut off right after the cat.
Old Aug 5, 2007 | 08:28 PM
rriddle3's Avatar
Yeah, you probably want to replace the cat anyway since it will have a negative impact on performance if it does plug up. If you can hear the rattle when you hit the cat it definitely is breaking up.
Old Aug 5, 2007 | 10:06 PM
Shizer's Avatar
Thanks man this is the kinda feed back I like on these forums I think I'll be here for awail.
Old Aug 6, 2007 | 04:51 PM
blazinloud's Avatar
check the laws.....if its safe cut it off.
Old Aug 6, 2007 | 05:42 PM
rriddle3's Avatar
Adam, he lives in West Virginia. The Federal government says it's illegal to run without a cat in the U.S. if your car is newer than (I believe) a 1976. It may also be illegal in West Virginia, I don't know.
Old Aug 7, 2007 | 08:41 PM
Blazer984.3's Avatar
Blazer984.3 is an unknown quantity at this point
Yes it is illegal. But, not if you drive "offroad" only. I know of a place that sells O2 sensor cheats. The site is called casperselectronics.c0m They are called O2 sims. They trick your comp. into thinking the O2 sensor is hooked up and working fine.
hillbillys10
Apr 14, 2013 01:04 PM
Squad-6
Headers, Intake, & Exhaust
May 17, 2011 10:29 PM
Bullfrog2099
Dec 16, 2010 07:25 PM
PaulO2288
17
Jan 20, 2010 01:39 PM
djbass_mekanik
Apr 22, 2006 06:15 AM
