Clunk noise and P1441 code
Old Oct 19, 2011 | 06:21 PM
97OregonBlazer's Avatar
97OregonBlazer is on a distinguished road
Post Clunk noise and P1441 code
Engine light came on last week but been so busy have not been able to get it check til' today. I went to autozone and they scanned it, came up saying:
Code: p1441
Failed- canister purge solenoid
Failed- Fuel tank pressure (FTP) sensor
and on top of this there has been a clunk noise starting today. Left work and while driving home started hearing a clunk noise
at first thought it was coming from underneath but found it coming from engine. i have a video i made of it, (i have stock exhaust 97' blazer) So the whole time you will only hear the clunk noise.
clunk noise 97 blazer - YouTube
Old Oct 19, 2011 | 07:11 PM
pettyfog's Avatar
Take your belt off and check all the pulleys for bearing noise and slop. Well, dont bother with the crank pulley..
Old Oct 19, 2011 | 08:38 PM
yeah one of the pulleys is wiggling even at idle. so im not sure on what to do for that
Old Oct 19, 2011 | 08:46 PM
pettyfog's Avatar
Which pulley.. it's pretty important. If it's your ac pulley, could end up costing big bucks.
Whatever one it is.. replace it soon. Idler and tensioner pullys are fairly cheap.
Old Oct 19, 2011 | 10:54 PM
trucktom's Avatar
trucktom is on a distinguished road
sounds like the cat is chunktifying itself and rattleing the peices in the muffler to me
Old Oct 20, 2011 | 05:24 AM
Silver00LT's Avatar
What is making that slight whistle after the noise? Like trucktom said it could be your cat self-destructing. When the exhaust is cooled down go out and shake the entire thing from underneath hitting it when your fist to see if you hear anything moving.
Those are weird codes just to be a warn out pulley. That is why I am leading towards cat self destruct. Did you smell rotten eggs on full acceleration before the noise then all of a sudden it lost the intense and/or disappeared?
Old Oct 20, 2011 | 04:04 PM
So i have codes for my canister purge solenoid, I just got my new fuel pump in today, and plan on putting it in this weekend. Not to mention it takes 15 seconds to start. just keeps crankin, crankin, crank then BAM. starts up.is this my canister purge solenoid causing it to take forever to start?
Old Oct 20, 2011 | 07:58 PM
BlaziNator's Avatar
BlaziNator is on a distinguished road
Might check your exhaust heat shields and skid plates for rattle if you have aluminum ones.
choover82
Jan 14, 2012 01:02 PM
slappymcnasty
Oct 25, 2011 06:53 PM
silvers10
Apr 9, 2008 06:50 AM
Sterling
Mar 30, 2008 11:26 PM
