Clutch Kit Replacement Blazer 4WD 1998
Old Aug 8, 2013 | 07:42 AM
austrochevy's Avatar
austrochevy is on a distinguished road
Question Clutch Kit Replacement Blazer 4WD 1998
Hi,
I'm from Austria and new here in the forum. My question is following: How I replace the clutch kit on a Blazer 4WD LS 1998? The problem is to remove the gear to replace the Release Bearing...
thanks!
Old Aug 8, 2013 | 09:04 AM
Jasongr81's Avatar
Jasongr81 is on a distinguished road
Best thing to do is to purchase a Haynes manual or whatever manual for your truck to do repairs to it. It will give you step by step on how to do almost everything to it.
I have replace a lot of clutches on vehicles but none on 4x4. Disengage your shifter handle from the transmission. Take your driveshaft out put a jack under your trans unbolt the trans from the motor I dont know if you need to unbolt the transfer case from it but you will probably have to. Unbolt the clutches take out replace. They should give you a alignment tool for your gears to go in as well.
ashelton96
Jun 13, 2012 10:27 PM
masterchf117
Jul 17, 2011 09:32 AM
MintyMadness
Jul 13, 2011 12:37 AM
speterson1011
Nov 11, 2010 05:28 PM
Red03
Sep 25, 2008 08:37 PM
