Coolant level?
Old 10-25-2011, 01:33 PM
JerryB52's Avatar
JerryB52 is on a distinguished road
Arrow Coolant level?
Periodically I open the radiator cap to check the coolant level. The clear plastic coolant tank is useless.
It is always low when i check it, (can't see any coolant).
It never reads too hot according to the temp gauge.
My question, is this normal?
I don't see any leaks of any kind...
Thanks. JB
No, it is not normal for the coolant level to drop. That is an indication that you are loosing coolant somewhere. If you haven't ever replaced the radiator cap, I would do that first & foremost as it is solely responsible for maintaining pressure in a properly sealed system. You can also have your system pressure tested (or test it yourself) to check for leaks. If you apply 16psi to the system (cap rated pressure) and it slowly bleeds down to nothing, you have a leak.
Old 10-25-2011, 06:01 PM
JerryB52's Avatar
I'll have to check it.
I'll Google and see what pops up.
Thanks.
Old 10-25-2011, 10:47 PM
98blazin's Avatar
98blazin is on a distinguished road
if your coolant level gets low, and its not leaking anywhere, you must be burning it...
(intake manifold gaskets)
AcerDeucerQ
12-03-2012 06:29 AM
Old Skool Soldier
03-29-2011 06:44 AM
mearltobias
TrailBlazer GMT360/GMT370 (2002-2009) Tech
09-19-2010 04:06 PM
Skeeter Cruz
03-04-2010 07:07 PM
2001blazer
01-30-2006 10:45 AM
Quick Reply: Coolant level?
