Crank no start has fuel and spark. Everything replaced!!
Old Dec 6, 2023 | 01:57 PM
  #91
LesMyer's Avatar
Old Dec 6, 2023 | 01:59 PM
  #92
Walleye Hunter's Avatar
Walleye Hunter will become famous soon enough
Originally Posted by LesMyer
With the factory hold down, you will not be able to turn the distributor. From what you wrote, it has to be in right (the same position where it started before). As long as you didn't turn the engine while the distributor was out, I would forget it and move on. Don't get hung up here.
You did have the rotor pointing towards the firewall both times, not away from it one time and toward it the other? Need to be sure.
Aaaaah, so the later models are different from my '91 in this respect?
Old Dec 6, 2023 | 02:03 PM
  #93
Blaz_r's Avatar
Blaz_r is on a distinguished road
Yes sir, got it all punched in correctly. It registers between 1.6 and 1.9 at 1500 rpm
What does spec 0 +/-2 degrees mean
Sorry just understood your request. Yes it drops to 1.2 when I rev above 1500 and let off
  #94
LesMyer's Avatar
Yep, later models have a hold down that locks it in place. Later models are completely different fuel injection system (apples and oranges)
Old Dec 6, 2023 | 02:21 PM
  #95
LesMyer's Avatar
Excellent job!! Now you are done with that distributor!! The spec means that anywhere between -2.0 and +2.0 is just fine.
Now do a "Clear Faults on ECU".
then evaluate and report
Is SES light off with engine running?
is Security light off with engine running?
How does it run?
Old Dec 6, 2023 | 02:34 PM
  #96
Blaz_r's Avatar
Is SES light off?
is Security light off?
How does it run?
No security light or check eng
But p0300 comes and goes as i refresh the screen. Which is consistent with how it runs. It runs smooth but then it will start vibrating with a slight drop in rpm not on the gauge but the sound.
Im not concerned though. You fixed it.
Old Dec 6, 2023 | 02:37 PM
  #97
Congratulations, it's good to see a success story. Nice work, LesMyer.
Old Dec 6, 2023 | 02:41 PM
  #98
LesMyer's Avatar
Probably we aren't done yet!! But getting it running and starting on it's own fuel injection was a big milestone. Sometimes it takes a lot of effort, especially through the Internet. Without a success once in a while, I would just pack it in and not bother anymore. The difference here is that Blaz_r really listened and tried to follow exactly what I was saying without getting distracted by YouTube or Facebook or skipping steps - searching for the easy way out, or pain old giving up. Very few will do what he did. So hopefully he will stick around so we can get his Blazer running as it should.
  #99
Blaz_r's Avatar
Yes sir, you are are a maverick among men. Your generosity is beyond measure. Thank you from the bottom of my heart.
Zell
Old Dec 6, 2023 | 02:44 PM
  #100
Blaz_r's Avatar
I know where to go and who to trust. In this day and age that is more valuable than gold.
