Directions on changing a 2002 Fuel Pump Kit
Old May 4, 2011 | 12:21 PM
bryanmine's Avatar
bryanmine is on a distinguished road
Default Directions on changing a 2002 Fuel Pump Kit
I am changing out my fuel pump, i got an idea how to do it, but does anyone have a step by step description on how to do this just to cover my bases as i go along with this?
Thanks.
Old May 4, 2011 | 10:55 PM
Frog's Avatar
Frog is on a distinguished road
I dont know of a how to on the web site here. But, you can go over to autozone and set up an account with them and they have some good repair guides with specs on most items on the trucks.
I it is not hard to do...but, it is recommended to have as little fuel in the tank as possible. If you have a truck you can, take the bolts outta the bed and lift up the front of the bed and support it with some 2x4's or do as some others and lift it up on the drivers side to get access to it. Or just drop the tank.
Make sure you de-pressurize the system before trying to remove the fuel lines and change the fuel filter while you are at it.
JTWard
Aug 22, 2015 04:53 PM
kimkoelbel
Jan 17, 2011 06:46 PM
tony991
Lifting Tech
Dec 26, 2009 07:12 PM
Lckyctch
Dec 30, 2007 05:38 PM
sampogers
Jun 17, 2007 05:04 PM
