Engine is jumping
Old Feb 18, 2014 | 03:53 PM
offroadsandimports's Avatar
offroadsandimports is on a distinguished road
Default Engine is jumping
My engine is jumping. This is only happening on the highway and it is scaring me. It is only happening when I go 60-70mph and I have my RPMs between 1000 and 2000. Why is this happening and is there any way to fix it?
Old Feb 18, 2014 | 06:05 PM
cleburne red's Avatar
What exactly do you mean by "jumping"?
And is your engine really turning less than 2k at 60+? At 60 mine is right at 2k. I've got 3.73s, though.
edit: By jumping, do you mean like the transmission is shifting into and out of od, or similar? Like it's hunting for the right gear?
Old Feb 18, 2014 | 07:10 PM
that might be it... but it just did it when i was going 40 too... this thing is seriously trying to murder me though so i might just get rid of it. and it is jerking forward and backward and the rpms are going from below to above 2000
Old Feb 18, 2014 | 09:54 PM
any check engine lights, or codes stored? I've had an intermittent problem with mine having a very high idle, ~2k rpm on occasion, and it's accompanied by a CEL and a IAC code, IIRC. Maybe your problem is the similar?
You might be able to rule out the transmission by selecting a gear, maybe 2nd or 3rd, instead of just D, and seeing if the situation still occurs.
Old Feb 18, 2014 | 10:16 PM
No check engine lights. The engine was actually acting perfect until this and today when it was accelerating by itself and I could barely brake. Before it started trying to kill me with this crap, it ran perfectly smooth though.
Old Feb 19, 2014 | 10:49 PM
I don't know if it's even possible, but maybe something is wrong in the cruise control system? On my '95, there are two throttle cables attached to the throttle linkage. One goes to the gas, and I always thought the other was for the cruise control. If you have that same setup, try disconnecting the cruise one.
Again, this might be totally impossible, and I'm really talking out of my rear end, but maybe it'll get ya started in the right direction.
Old Feb 20, 2014 | 06:30 AM
rriddle3's Avatar
Since the OP has two threads concerning the same issue and has had more responses in the other one, this one is closed.
*Thread Closed*
creeder_87
Feb 13, 2010 01:12 PM
BobTheBlazer
Jul 16, 2007 04:18 PM
breezy32784
Jun 29, 2007 12:29 PM
soul_seeker77
Mar 11, 2007 04:41 PM
Hanr3
Mar 2, 2007 11:32 PM
