Engine knock.......
Old Oct 13, 2015 | 08:18 AM
Impact's Avatar
Impact is on a distinguished road
Default Engine knock.......
To make a long story short I dropped a nut down the intake and did know it and started engine. I heard the nut go through the engine and now I have a knock (I know I was a dumbass). The compression on the cylinder was low at about 90 while the rest were about 120. I already checked the valve train and everything is fine and the it actually runs normal. I removed the #1 cylinder plug wire and the knock just about goes away, I can hardly hear it. Does this mean that it is a rod bearing spun or something else. I am trying to determine what the next step is. Thanks
Old Oct 13, 2015 | 12:46 PM
odat's Avatar
OUCH - bent rod, hole in piston, bent valve, cracked head, ECT. next step for me would be tear it down and see what damage has been done - either way I would think it can't be good -
Old Oct 14, 2015 | 08:00 AM
Impact's Avatar
I put a scope down the spark plug hole and didnt see much damage. I did have compression on the cylinder so am hoping there isnt damage that I cant see. I am just wondering if it is piston slap or a spun rod bearing. Either way the engine is not gonna last too long. It has over 200,000 miles so it has had a long life. Sad, it runs so well now that I changed the fuel pressure regulator.
fredguaz
Dec 11, 2017 08:11 AM
ejschultz
May 23, 2009 04:15 PM
Talusgirl
Apr 28, 2008 08:34 PM
deadpool
Apr 2, 2006 06:09 AM
93LT
Jan 9, 2006 09:25 PM
