Engine removal
Old Nov 2, 2010 | 09:59 PM
Flat540's Avatar
Flat540 is on a distinguished road
Default Engine removal
I,ve done the search function thing,but still unsure! Can I pull the engine & trans. Together on a '02 4.3 a.t. 4 wd. Without splitting the trans.I have an '01 zr2 with a badd kknock and bought a low milage wreck with a good drive train and want to do the swap as painless as possible.Any sound advice.?
Old Nov 2, 2010 | 10:03 PM
mh86334's Avatar
mh86334 is on a distinguished road
I'm not sure about pulling them out as one...when I did mine, I dropped the tranny first. If you decide to go that route, make sure you have some long extensions ready to get the top and side bellhousing bolts. Clearance is real close, and it helps if you undo the aft mount and let the rear of the tranny drop down, then go over the top to get the bolts. All in all, it was a pretty straight forward swap. Just remember about the two engine grounds on the back side of the block...hard to see, easy to forget.
Old Nov 2, 2010 | 10:13 PM
Flat540's Avatar
I have read how to remove the trans.and get at upper bellhousing bolts but..... Can I do the job In one piece,Without splitting the trans. I want to reinstall the newer lower milage trans.along with the new engine,and save myself some work if it is possible. !! Thanks..... J.W.
Old Nov 2, 2010 | 10:19 PM
mh86334's Avatar
I am sure it can be done, if you have enough clearance underneath to tilt the assembly out...or pull the front radiator support.
R Deschamps
Nov 2, 2011 08:39 AM
nite_vison
Apr 13, 2008 06:19 PM
Navy85
Mar 1, 2008 07:57 PM
blazernate1002
18
Feb 12, 2007 11:11 PM
Bill_m.
Aug 11, 2006 06:30 AM
