Engine removal (body mounts)
Old Oct 5, 2019 | 11:01 AM
  #21
Ebbervonfloyd's Avatar
Ebbervonfloyd is on a distinguished road
Another thing that gave me trouble was the ground connection on the back of both heads. I assumed that it was all #10 wrench size and it turns out it was 5/8 std, plus the bolt was a 3/8 std also.
Old Dec 11, 2019 | 08:59 PM
  #22
PSS-Mag's Avatar
PSS-Mag is on a distinguished road
Update:
Motor is in, so far everything seems great! (Knock on wood) had to sacrificed a baby giraffe to the car Gods but they seem mostly pleased.
Except have a Low Current Knock Sensor Bank 1.
Wish I'd known that while I had the motor out.
but if that is the worst thing, guess I'll take it.
Finished last Thursday, driven 150 miles so far.
Old Dec 11, 2019 | 09:15 PM
  #23
PSS-Mag's Avatar
Advice/what I learned.
Do not have to lift the body but I am glad I did. if I had a 4 post lift I'd taken the body completely off.
Second thing, I learned: Protect your fuel lines like your life depends on it. If you don't, you will be kicking your self in the family jewels.
Best advice, 2 essentials that you will want to make sure that you have.
Load leveler for your hoist. ($30 at harbor freight.)
Set of Crows feet wrenches. ($20 for a set of standards and metric at harbor freight.) Specifically 5/8" for the fuel lines.
unbolt the motor mounts from the block before removal.
after you have wrestled and contorted to get the motor mounts out. You can notch the bottom holes of the mount to ease reinstallation. This makes reinstallation take 10 mins per side vs hour per side.
If I think of anything else I'll update.
trevhoff
May 20, 2013 07:54 PM
TomSawyer
Feb 15, 2010 02:11 PM
samuknow
Apr 8, 2009 10:33 AM
ShaneInsane
Lifting Tech
Sep 19, 2007 05:52 PM
Jackal
Feb 15, 2007 07:18 PM
