Engine swap help?
Engine swap help?
I have a 2000 Blazer 4.3L that the intake gasket failed and it was not shut down in time. Motor is not locked up but does have busted rod/rods. I have exhausted my means of searching for what years motors will work in this blazer with no definitive results. Is there a website that gives compatible year motor swaps? Most 2000 motors I have found have really high miles or unknown miles. I do have a lead on a 2004 xtreme blazer 4.3 with low miles, but cannot find info if that is a compatible swap for my 2000. Any and all help/info will be greatly appreciated.
Thank you in advance,
Matt.
Matt.
You can use any year short block from 96 and up then swap your top end with new gaskets.ON the 2000 block I think the knock sensor uses a larger hold so check that.If this is indeed the case dill and retap the hole to match size.
Matt.
Matt.
U can use a newer motor, if u go 2002 & up u will need to reuse your intake manifold! Oh and u will need to drill and tap the block to accept the older style knock sensor...it's a 1/4 not thread btw....& if memory serves me right the 2001 & up sensor take a 8x1.50 ? U cab make it work....I bought a 98 motor that was rebuilt & put it in my 2001....only issue was knock sensor...
Thank you everyone. Found a 2000 GMC Jimmy that had been in a rollover accident with acceptable miles on it. I plan on replacing all gaskets along with plugs and wires in this swap, any recommendations to anything else I should check/replace while doing this swap?
I would do intake gasket, front main seal & of course rear main!!! Crap I just retread your post....lol u are replacing all gaskets???? not a bad idea at all!! How many miles this got on it???? I scored a motor from a 98 that was remanned by Marshall engines with less than 40k!!!! I went & looked it over real good and reassembled it and shot a few coats of Chevy orange on it!!! Of course the usual thermostat,water pump,plugs,wires,cap,rotor,distributor gear was worn!!! Make sure u look at that real good!!!! u probably will want to change out your motor mounts!! I had one come apart and other wasn't far behind it at least flush your oil cooler lines....as well!!! I just bought new ones....another $30
gmoney30
07-05-2010 08:51 PM
gmoney30
01-22-2010 07:07 PM
HelpMYBlazerPlz
04-24-2009 11:11 PM
