engine turns but no spark
Old Nov 20, 2010 | 11:57 AM
vimal's Avatar
vimal is on a distinguished road
Default engine turns but no spark
hey guys ive got a 1999 blazer with 4.3l vortex v6 lump UK spec and i had a problem with the central locking remote they didn't want to know the car and i could not override the codes for the security system, however after some research i managed to re sync the remote to the car and the security light goes off but i have no spark ?? ive replaced the coil and took the dizzy cap off and cleaned all the point and put it back together but i have no luck the fuel pump seems ok and can be heard when the ignition is turned on could anyone help please thanks
Old Nov 20, 2010 | 12:23 PM
robertr728's Avatar
robertr728 is on a distinguished road
Old Nov 20, 2010 | 12:28 PM
vimal's Avatar
hey thanks for that will give it a go tomorrow morning thanks
Old Nov 21, 2010 | 07:25 PM
vimal's Avatar
i checked everything from the link ( https://blazerforum.com/forum/showthread.php?t=45942)but still no spark as the problem occoured originally form the cars securty system could there still be a fault with it? and is there anyway i could bypass the system ?
however the only thing i didnt do was Replace distributor rotor and the cap gave them a good clean tho
Last edited by swartlkk; Nov 22, 2010 at 02:24 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 22, 2010 | 08:18 AM
autojunkie89's Avatar
autojunkie89 is an unknown quantity at this point
idk if a 99 still uses it mine was a crank no start a while ago the guys at work helped me diag it found the ignition control module fried, its in the distributor held down by two bolts and a two wire plug on mine at least if urs has this make sure u tighten those bolts before trying to start it cause it grounds thru the base of the module and will short out again good luck mine was a 94 cpi motor
Soldat251
Jan 28, 2024 10:36 AM
drummerdude84
Jan 7, 2011 01:18 PM
Kappa96451
Jan 6, 2010 05:32 PM
rooster
Jun 7, 2007 08:40 AM
ryandannar
Sep 13, 2006 05:19 PM
