Engine turns over does not crank
Old Dec 21, 2012 | 01:25 PM
Ksweat1241's Avatar
Ksweat1241 is on a distinguished road
Default Engine turns over does not crank
It's a 99 blazer 4.3 auto. The head was replaced and after I got it put back together the car won't start. It turns over and it sounds like its a fuel related issue. It gets 60 psi to the Schraeter valve with key on. And also the ignition won't crank the motor. I replaced the icm already and still nothing and the new icm went bad when I put it on. Where would I start looking to find the reason why it went out an would it be related to the ignition not wanting to crank the engine ?
Old Dec 21, 2012 | 03:27 PM
Diaita's Avatar
Ignition switch is good?
Old Dec 21, 2012 | 04:39 PM
Ksweat1241's Avatar
That was my first thought. It turns everything on but it's like the contact points just wore out and it's not sending any power to the starter. Regardless of the switch being bad it has a fuel pressure problem that needs to be fixed. I've never had a engine lose fuel pressure after taking off the intake and especially when it was running just fine before the head was replaced
Old Dec 22, 2012 | 04:37 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Check all your wiring to the starter and battery.Make sure everything has a good connection or none of them are broken.
CbBlazer22
Mar 4, 2014 02:05 AM
1998mom
Jul 30, 2013 12:03 AM
2001Xtreme
Sep 12, 2011 10:52 AM
drummerdude84
Jan 7, 2011 01:18 PM
