Engine Will Not Turn Over
Old Oct 20, 2015 | 10:44 AM
Blaine213's Avatar
Blaine213 is on a distinguished road
Default Engine Will Not Turn Over
Battery is good and fully charged.
Connections are Clean and tightened
All Lights and radio work
Lights do not dim when key is turned like it does when connection is bad
No sound, no clicking or anything
Would this be the starter? Never had a problem with starter previously. Has never dragged or anything.
Or is there any type of module associated with this?
Any ideas?
Old Oct 20, 2015 | 04:34 PM
Year, make, model, engine, transmission, rear wheel drive or 4WD?
Old Oct 20, 2015 | 05:54 PM
Blaine213's Avatar
2001 Blazer 4.3, auto, 4wd
Old Oct 21, 2015 | 02:26 PM
The red wire at the starter must show battery voltage at all times.
The purple wire at the starter solenoid must show battery voltage with the ignition in the START position.
Voltage Drop Testing is 100% accurate. Check positive and negative sides of the circuits.
krazykracker
Feb 2, 2013 12:44 PM
hensonjd55
Sep 26, 2010 04:30 PM
greeneyes1975
Jul 11, 2010 02:37 PM
rippersvf2
Jul 21, 2009 05:09 AM
BoAtlanta
Jul 5, 2006 06:06 PM
