Engine wont crank after adding seafoam
Old Jul 22, 2012 | 09:55 AM
NCSurvival's Avatar
NCSurvival is on a distinguished road
Originally Posted by 97cherryblazer
Did your break booster line pop off? Thats what the stiff brakes would be and the engine jolting from the vacuum leak.
Or he actually tried to pull spark plugs because he went on the advice given to him prior on in the thread about hydro locking, and didn't pop wires back on correctly. The stiff brakes would be from the truck dying. (No power brakes) to the OP: How did the truck run before the oil change, and was it due/overdue for it? Next seafoam treatment, remember to keep the vehicle running... lol It's what I do. One hand on the throttle keepin her running, and the other pouring seafoam. Thick white smoke is the result of the seafoam doing it's thing.
Old Jul 22, 2012 | 02:37 PM
slowsinglecam's Avatar
slowsinglecam is on a distinguished road
If he did let is set for sometimes it would of leaked passed the rings and into the oil pan. Thats if it was hydro locked.
Old Jul 22, 2012 | 04:41 PM
xgiovannix12's Avatar
id pull the plugs and crank the motor by hand from the crank in front of the motor.
Hopefully the seafoam is sitting on top of the piston and is not letting the motor turn over . This happened to me on a ford 351 once. It was unknown where the water came from tho .
Hopefully no damage was done to the heads.
Old Jul 23, 2012 | 02:23 AM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
He already got it started.. were just now trying to figure out the stiff brakes then engine jolting issue.
But i also would have pulled plugs like you said
Old Dec 9, 2012 | 11:10 PM
joshuajay1000's Avatar
joshuajay1000 is on a distinguished road
I was actually thinking about seafoaming my truck hoping to fix the P0304 misfire code I have and I found this video, it's the official "HOW TO" video. Hopefully it will show you what you did wrong. Good luck.
phxjosh
Dec 1, 2013 06:28 PM
dj00140
May 20, 2013 06:37 PM
Bullfrog2099
Engine & Internal
Dec 20, 2010 09:30 PM
DaleA
Suspension Tech
Dec 26, 2008 09:03 AM
sysmex
Performance & Brainstorming
Jul 14, 2007 07:46 PM
