Faulty Shifter Cable ?
Old Sep 11, 2017 | 11:50 AM
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
Default Faulty Shifter Cable ?
I have a problem with my shifter cable. I can shift into R, N, OD, D, 1, and 2 just fine. But when Im done driving and go to put it in P the shifter handle just goes up as if nothing is attached. I have to put the E brake on and hand shift it into P. Shifts through gears fine just doesn't up shift back to P and misses every other gear along the way. Also I can't hand shift it back to P if the shifter **** is in the P position.
Attached Thumbnails Faulty Shifter Cable ?-20170911_102626.jpg   Faulty Shifter Cable ?-20170911_102703.jpg
Old Sep 11, 2017 | 04:56 PM
ChuckNTruck's Avatar
Judging by how bad that looks, I would highly recommend you replace that cable. vehicle not going into park can cause a major issue if you forget about it one time. I have personally seen vehicles get away from people and know one person that got run over by their own vehicle.
matthewp
Apr 4, 2021 09:16 PM
BlazeOn
68
Feb 7, 2019 10:24 AM
jasedude
Nov 24, 2010 04:03 PM
rbcar1
Dec 13, 2009 10:20 AM
devestator_x
Dec 26, 2007 10:08 AM
