front diff, I need help
Old Sep 27, 2011 | 06:58 PM
00blazer13's Avatar
00blazer13 is on a distinguished road
Default front diff, I need help
2000 s10 blazer 4x4. Changing front diff outer shaft seal and bearings. Passenger side was leaking, so I am doing both sides. Is there a trick to getting the driver side shaft out of the diff case? Or do i need a bigger hammer?
Old Sep 27, 2011 | 07:18 PM
NVANZEE's Avatar
put a piece of 2x4 on the backside of the shaft from under the truck. Then a few good wacks with a hammer should pop it loose.
Old Sep 28, 2011 | 05:38 PM
00blazer13's Avatar
Thanks, I got it apart.
Old Sep 28, 2011 | 06:11 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Hey. I need to fix the same thing, but only the driver's side. How big of a project is it? I just need to replace the seal. Is it worth $120 to have a shop do it?
Old Sep 29, 2011 | 06:47 PM
00blazer13's Avatar
Not a bad job if you have tools. I rented a ball joint separator. A pry bar and a thin piece of wood got my axle out. I don’t c paying a shop for this job. This is my first time doing this job. Ask yourself, how much is my time worth? Good Luck!
Old Sep 29, 2011 | 07:54 PM
Well, I have all weekend since work's rained out tomorrow. I may take it on. And maybe bed liner the rockers and such too. I need something to keep me busy! Thanks for the tips.
Old Sep 29, 2011 | 08:25 PM
98blazin's Avatar
98blazin is on a distinguished road
i did my driver side front diff seal last month.
i bought the seal allready pressed in the diff plate for 55$cnd at the gm dealer.
took about 1 1/2 hr to do it. was pretty simple/easy.
CodyOrtegren
Jan 8, 2012 11:23 AM
jakem
Apr 22, 2011 12:34 AM
tofunater
Jan 14, 2011 08:11 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
alangri
Apr 9, 2008 04:11 PM
