Front Transfercase ?
Old Feb 8, 2011 | 04:59 PM
jakem's Avatar
jakem is on a distinguished road
Default Front Transfercase ?
So my 2000 blazers 4x4 stoped working so i started checking it out and what i found is that the vacume actuator is not strong enough to pull the pin in to make it lock in. I pulled it in with chanel locks nut it was very hard to do. I replaced the actuator and actuator cable just to make sure it wasen't them. So do i have to change out my transfercase? Or can u fix the transfercase? Thanks for any help.
Old Feb 8, 2011 | 05:15 PM
abig84's Avatar
there is a switch on top of the transfercase that transfers the vacuum to that actuator that makes it work. so either that switch is bad or or a line is leaking
Old Feb 8, 2011 | 05:17 PM
NVANZEE's Avatar
Are you talking about the transfer case or do you mean the front differential? To me it kinda sounds like you are talking about the front diff but i could be wrong.
Old Feb 8, 2011 | 05:24 PM
jakem's Avatar
I think ur right i think it's thr front diff? im talking about the part were the actuator cable push's into ?
jman_08
Aug 21, 2008 02:05 PM
blzR
Dec 19, 2007 05:44 AM
broken_blazer
Apr 15, 2007 02:09 AM
broken_blazer
Apr 13, 2007 01:25 AM
napalm dan
Jan 13, 2007 08:55 PM
