Fuel odor problem!
Old Jun 12, 2007 | 04:53 AM
sh1520's Avatar
sh1520 is an unknown quantity at this point
Default Fuel odor problem!
Hi all--1st post here. My '96 Blazer 4.3l,4wd has recently had a strange problem. Whenever I fill up the fuel tank, I get a strong odor of gasoline. However, once about a 1/4 has been burned, there is no odor. I have just been filling it to about 1/2 to 1/4 full to avoid the smell. I don't notice any leaks at all either.Any ideas what this could be? Tank, lines? I replaced the fuel filter this month and still get the odor after filling up. I'd appreciate any input. Thanks again!
Old Jun 24, 2007 | 04:48 PM
nemesis_SS's Avatar
nemesis_SS is an unknown quantity at this point
Default RE: Fuel odor problem!
Maybe the hole is on the top 3/4 of the tank, or, the seal around the top of the tank is gone. Try running it and then looking under there with a flashlight to look for spray.
Old Aug 4, 2007 | 09:17 PM
blazerboy124's Avatar
blazerboy124 is an unknown quantity at this point
i have this same problem. i couldnt figure it out for the longest time i brought it to a shop and they said the same thing as nemesis_ss. it might also be the lines because my buddy's blazer had faulty fuel lines (they were cracked) and they would slowly drip.
Old Aug 7, 2007 | 05:35 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
there is a plastic fuel vent valve on top drivers side of the tank. it is a 90 degree plastic elbow that has a rubber hose connected to it. On mine, the valve elbow cracked and was leaking fumes. I could mainly smell it at a few stoplights right after I filled up. The part was not very expensive, around $20.
billfrank85
Jul 19, 2013 12:04 AM
swartlkk
Jul 15, 2011 01:47 PM
greg20fan
Apr 2, 2010 05:27 PM
mysssticghost
Dec 12, 2007 09:52 PM
hoffyinaz
Feb 1, 2007 06:23 AM
