fuel pressure for 1999 blazer vortec question
Simple questions guys. I was told that I have tor elieve pressure prior to replacing fuel filter. I push in the schrader and got no fuel pressure release. I remove old filter - no pressure. I notice "low fuel" light kicks on half the time I drive even after filling up. I notice when this light comes on it idles worst.
1. Is there a problem if theres no pressure within my fuel system?
2. Is the rough idle, false "low fuel" lamp related to this you think?
How do I troubleshoot the leak?
JDS
thanks guys
thanks again dude hope to hear some thoughts.
JDS
thanks guys
Last edited by swartlkk; 04-15-2010 at 06:25 AM. Reason: **Combining Consective Posts** - Please use the EDIT feature to add information to your post if another member has yet to reply.
Please be patient. You replied to your own thread 1 minute after you originally posted...
If your fuel pressure is bleeding off, you have a leak in the system. Your problems could be related, but without a fuel pressure test as detailed in the Tech Article (DIY) section and specifically looking at the leak down rate, anything would just be a guess.
wantitgoing
01-04-2015 10:59 AM
AndrewO1991
30
11-14-2012 09:53 AM
cas
31
10-20-2012 02:01 PM
sbrookover
12-25-2009 02:42 PM
96blkblazer
02-26-2009 04:29 PM
