Fuel Pressure Problem
Old Jul 22, 2010 | 03:11 PM
Unlimitedsp's Avatar
Question Fuel Pressure Problem
I have read the 96+ Fuel Diagnostics thread after having some starting issues when the truck reached operating temps. In the morning it starts right up no problems. After driving for a bit and reaching operating temp it takes a bit to start after you shut it off. I tested to see how long it had to sit for it to start normally and after 6 hours it still hesitated to start. After 8-9 hours it would start right away or with a little chug. The truck runs fine after its starts. Idles fine and everything.
I went ahead and replaced the fuel filter, ICM, cap, rotor, plugs, wires, coil and FP relay, with no fix.
I then tested the fuel pressure and heres the problem. At ON position Im getting 51psi. Its low. but heres the thing, once you hear the fuel pump stop the pressure will drop down to 5psi in a matter of seconds. Turn the ignition off and the same thing. It will not hold. With the engine running It stays between 51-55psi. I have little to no smoke at start-up and no real smell of fuel or line leaks. So you would think if an injector was leaking that much fuel, it would be noticable.
Next thing I need to do is test it from the fuel filter and see if the fuel pump is loosing pressure.
In the mean time anyone have any input? Suggestions?
Old Jul 22, 2010 | 04:21 PM
You have a leak. If it isn't external, it will either be the FPR or the check valve in the tank. The pressure test at the filter will let you know.
Old Jul 23, 2010 | 06:50 AM
seanpconley's Avatar
seanpconley is on a distinguished road
Gotta be the FPR the pump is good because it seems like it sends enough fuel in the am to get it to fire..Then when it gets hot it takes a little to start because the leak is basically flooding the engine in small amounts. I just changed mine and it runs like the ol day's..if you don't change it too much raw fuel well start to mess with your CAT
racinghoss
Sep 10, 2023 08:56 PM
Bad Ramer Jamer
Sep 16, 2008 10:32 AM
Spartan66
Jul 11, 2008 02:34 PM
gpr13902
Apr 29, 2008 10:12 PM
adlady
Aug 26, 2007 01:35 AM
