Fuel pressure Regulater
Can i replace the fuel pressure regulater on a 95 blazer vin w its leaking on my spider injecter i tried taking the regulater off useing a torx bit but the bolt has a raised center to it that wont let the bit go in any idea's i really dont wanna spend a few hundred right now on a new spider injecter
RE: Fuel pressure Regulater
You can get them from advance auto for $44. When I bought one, it came the bit and o-ring. Its from motormite part number 55162
You need a safety torx bit to remove the screws holding the FPR in.
I was able to remove mine by gripping it with a pair of plyers the screws are not very tight or you can get a bit set from Harbor Freight pretty cheep
I got the FPR from AutoZone - it's a Dorman/Help! part - and it came with the security torx bit.
cool thanks alot besides the regulator and the nut kit what other parts might i want to consider checking for leaks like i said money be a little tight right now thanks
That would be the extent of it unless the individual fuel lines out to the poppet nozzles were leaking.
Check out Lindertech.com. They have a kit that adapts the newer, more robust FPR from the 96+ engines for use in the CPI spider. Only requires a bit of modification to the CPI injector body.
i have to check my spider or regulator too because i found a little bit of fuel at the bottom of the intake. any tips on where exactly to look? thanks
brianroark
06-25-2010 03:14 PM
Spartan66
07-11-2008 02:34 PM
riverjamie
09-24-2007 08:21 PM
aspenpup
09-09-2007 07:11 PM
jlinder
08-21-2005 11:08 AM
