Fuel pump question
Old May 18, 2022 | 09:51 AM
roosterc's Avatar
roosterc is on a distinguished road
Default Fuel pump question
So I understand the fuel pump on my 88 S10 blazer has two sources of power. One from the fuel relay and the second from the oil pressure sensor. Is this correct? In trying to run down a issue I have disconnected both the relays by the driver's side fire wall and the oil sensor adjacent the distributor. The truck is still running the same. The fuel pump is still getting power.
Why is this? What am I missing?
The issue I was running down was the truck would start to lose power like it wasn't getting enough fuel then if you shut it off it wouldn't restart. It will start again after sitting a long time.
I thought maybe I had a bad relay and a bad oil sending sensor both out or working intermittent or one one out and one working intermittent.
I can't really fix my issue till I can recreate it to see what's causing it. Any ideas?
Old May 18, 2022 | 03:25 PM
GeorgeLG's Avatar
2.5, 2.8 or 4.3L engine?
George
Old May 18, 2022 | 03:28 PM
roosterc's Avatar
George
it's a 4.3
Old May 18, 2022 | 03:47 PM
GeorgeLG's Avatar
Depending on your configuration there are up to three sources of power to run the fuel pump:
The oil pressure switch
The fuel pump relay
The redundant fuel pump relay
Fuel pump priming tab (if energized or hacked)
All three/four output power on Gy (or Tn/Wht) wires which have a splice/junction on the way to the fuel pump motor.
See attached.
George
File Type: pdf
Old May 24, 2022 | 07:40 AM
roosterc's Avatar
The fuel pump relay
See attached.
George
Thanks, I will figure out if the priming tab has been jumped. That's all that's left unless I'm mistaken about the location of the redundant relay.
It's not really an issue, I just want to know.
the issue that got me on this has been resolved. It was a bad ground wire into the fuel pump. I went ahead and replaced the pump and sending unit.
SteveS
Sep 19, 2012 09:18 PM
89DropTop
Dec 2, 2011 12:11 PM
98BlazerBoy
Jul 29, 2011 05:17 AM
mugurtis
Apr 17, 2011 10:18 PM
cage47
Performance & Brainstorming
Sep 26, 2009 11:08 AM
