Fuel pump question need answer a.s.a.p
yea u can use the fuel pump if u want to, as long as they are both either 18 gallon metal tanks or 18 gallon plastic tanks.....i would just take apart the sending unit and replace the pump youll need a flathead a pair of slip joint pliers and 5 minutes the pump is reall easy to change in those plastic sending units...
Your truck is just a trim level on the standard S-series Blazer so saying that it is "not a regular blazer" is not true when talking about pretty much anything other than the optional trim pieces that make it a Trailblazer trimmed Blazer.
That said, comparing the part numbers on RockAuto.com should give you definitive proof.
eclark69
06-21-2012 02:41 PM
janet7
05-24-2011 02:16 PM
89K5gasahollica
03-19-2010 02:47 AM
