Generic question.. What part is this??
Old May 24, 2008 | 11:21 AM
hls811's Avatar
hls811 is an unknown quantity at this point
Default Generic question.. What part is this??
OK - this is going to sound like such a basic, generic question - but what is this part in the picture???
I've noticed recently when driving a tapping sound - its not loud at all, I can really only hear it when I have the radio off - but the other day I happened to have the hood opened and noticed that it was this "thing" making the sound.. When the belt is going around, that part in the middle (with the imprint and yellow writing) would stop for a second and then the tapping was it starting back up. Is that normal or something I should be concerned about??
Again - I apologize if this is so basic - I'm not sure how else to phrase it! (I'm not a mechanically inclined person!)
[IMG]local://upfiles/9387/86A12C65BC1F4E57BD2D28D0A2FA1FF7.jpg[/IMG]
Old May 24, 2008 | 11:56 AM
TripleBlackBlazer's Avatar
Default RE: Generic question.. What part is this??
That is your A/C compressor. It does normally cycle on and off. If it is tapping as you say I would wonder if it is on its way to seizing.
Old May 26, 2008 | 01:54 PM
mr.vls's Avatar
It is the A/C compressor and they do get noisy. However as long as your air is blowing cold I would not worry about it. The reason it cuts in/out is that the compressor is driven by a magnetic clutch that is energized on/off again depending on the A/C line pressures. If your pulley bearing was going out it would be a continous whine.
Old May 26, 2008 | 02:26 PM
hls811's Avatar
Cool.. Thanks guys.. It is blowing cold air so I'll let it go for a while.. I'm just glad its not something that could lead to a breakdown!!
Old May 26, 2008 | 05:43 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
Well if its cycling too much it most likely means you are low on coolant, or maybe too much also. Its not uncommon for some coolant to be lost over time through the seals. It is when it gets to the point of mine when the compressor is trash.
spider21
Nov 17, 2011 06:27 PM
Daho78
Jun 15, 2010 09:32 PM
Marcin
May 11, 2009 12:43 PM
sasquatchfound
Dec 26, 2008 09:15 PM
Balance
Engine & Internal
17
Jun 10, 2006 03:43 AM
