Grounds to heads
Old Nov 24, 2010 | 08:27 AM
vega7677's Avatar
vega7677 is on a distinguished road
Default Grounds to heads
Guys, just bought 96 Blazer LS 2 door. I have been chasing P0300 code on it. Was trying to check grds , on grds to the heads,how do you even see them, let alone check them !!!
Sherman
Old Nov 24, 2010 | 08:11 PM
franklin's Avatar
franklin is on a distinguished road
what do you need to check the grounds for? I don't think that has anything to do with that code you have. I think a p0300 is a multiple cylinder misfire.
Old Nov 24, 2010 | 10:36 PM
blazerpower's Avatar
blazerpower is on a distinguished road
yea it is. its just time for a tune up dude. and possibly a camshaft position sensor
Old Nov 25, 2010 | 09:48 AM
vega7677's Avatar
I'm just checking everthing that might have anything to do with the P0300 code. 63 FP on prime,56 while idleing,has good compression on all cylinders , new cap & rotor, new wires & plugs , new dist gear, new crank sensor , vacuum is about 18 at idle .
Also , FP doesn't leak off when its shut off,will hold at 52 for at least 20 mins.
I think I have at least 1 bad 02 sensor (02S12 on my Actron CP9185 scanner if I'm reading right ,just got it) , will see about replacing it tomorrow.
LT01
Nov 2, 2011 04:12 PM
kaynos
Aug 11, 2011 03:01 PM
Riktar
Detailing
Aug 21, 2010 07:46 AM
ExplicitYourSelf
Oct 13, 2009 10:18 AM
upblazer95
Jun 16, 2009 09:56 PM
