Hard start
Old Mar 13, 2014 | 08:50 PM
  #21
TZFBird's Avatar
TZFBird is on a distinguished road
Maybe the starter is just dirty. I'm pretty sure that is part of my slow cranking also.
Old Mar 14, 2014 | 12:47 PM
  #22
BlazerHeadaches's Avatar
BlazerHeadaches is on a distinguished road
thanks for the tips guys! this site is freaking sweet! all the suggestions and info I learned on here helps a lot keep it up! I will update after I check starter battery. thanks again.
shane
Old Mar 19, 2014 | 11:33 PM
  #23
New battery!cold hard start Problem solved!?!?! I had it checked twice same results. They said it was ok. Went through old receipts and the batt was 5 yrs old. So it was due and bam first crank every time. Still have not figured out the bogging down losing power problem. Going to search around Nd if need be start a thread. Thank you all for the tips and advice
Shane
Old Mar 20, 2014 | 03:20 PM
  #24
jimspahr@msn.com's Avatar
Shane---Thanks for your up date on the problem/solution! That is very helpful to the forum because others are having similar problems or will have eventually. I may have to buy a new battery soon. Thanks!
Old Mar 21, 2014 | 12:27 AM
  #25
Jim no problem man! I have come across so many threads with dead ends. It's super annoying but at the same time I've learned a lot about my blazer just from lurking around on here! I'm glad to have helped as you all have helped me and it will continue to lurk on a daily basis. Thanks again
Shane
Kevin Gore
Dec 13, 2013 09:35 PM
dubaholic2
May 24, 2011 12:44 PM
ejxjohnson
Sep 10, 2010 08:21 PM
Purple95Blazer
Aug 4, 2006 12:06 AM
vmx120
Dec 2, 2005 12:19 PM
