Hard time shifting
Old Sep 5, 2009 | 11:43 PM
nickt892003's Avatar
nickt892003 is on a distinguished road
Default Hard time shifting
I have a 1988 blazer with a v6 2wd. When i put it into reverse it is just fine...then i go into drive and take off it wont shift into 2nd unless i rev it up and almost red line it.then it will get stuck in between gears for a lil bit then shift. Then when i coast it stays in gear and engine breaks itself because it wont shift up. I got the truck from a girl that said when it happen her dad would go under the hood and get something unstuck. She said her dad said something would get stuck and cause that to happen. I am a mechanic myself and have no idea what that would be. This is my first chevy so im trying to figure out how this truck is set up. thanks!
Old Sep 6, 2009 | 12:32 AM
AJBert's Avatar
Sounds a heck of a lot more like a tranny problem than an engine problem, and I think this girl took you for a ride.
Old Sep 6, 2009 | 10:54 AM
well the only thing i can think of is the kickdown cable is stretched. the girl is my brothers freind and wouldnt be the type to screw me over. Its the second transmission in the truck. only about 50k on it. Do the 88s have a solenoid in the trans??
Old Sep 8, 2009 | 08:03 AM
cjmor1804's Avatar
cjmor1804 is on a distinguished road
my '89 4x4 has the same problem, but sometimes it will shift just fine. i came to the conclusion that when i had my truck taken in to have the transmission filter replaced, they didn't tighten the bolts to the pan!! so of course now i have a pretty good fluid leak, which probably caused the rough shifting. my only thought and hope is that maybe the fluid, filter, and gasket needs replaced again. any tips on draining the fluid from the torque converter? oh, and how would a stretched TV cable (kick-down) cause hard up-shifting? would'nt it just cause the tranny to not downshift on time?
echild
Dec 16, 2009 05:55 PM
bwoodfire45
Jan 8, 2008 01:58 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
states
Engine & Internal
Dec 16, 2006 03:57 AM
Swblazer
Aug 15, 2005 01:41 AM
