Head gasket maybe?
Old Nov 26, 2008 | 03:20 PM
bswitz's Avatar
bswitz is an unknown quantity at this point
Default Head gasket maybe?
Hi hope someone knows when driving the Blazer over heats. when I open the hood standing in front and looking right behind the alternator I see steam and bubleing coming from under the valve cover.
Isit a head gasket?
If so how hard is it to replace on a blazer? it's been many years since I've done one.
Old Nov 26, 2008 | 06:37 PM
Default RE: Head gasket maybe?
Do you have coolant in the oil? Is it coming from the valve cover or from the intake manifold gasket (they are very close together)?
Old Nov 27, 2008 | 07:41 AM
bswitz's Avatar
No I don't think so it just looks like oil not milky or anything that was the first thing I looked for. When I look directly behind the alternatorright below the heater hoses (which was my first thought as to what was leaking) I could see the steam /bubbles coming from where the valve cover meets the engine.
Old Nov 27, 2008 | 07:58 AM
salvy's Avatar
salvy is an unknown quantity at this point
It's probably the intake manifold gasket like mine, rent a pressure tester, pump it up about 10-12# see if you could seethe leak, look below the truck as well, try to track it down that way.
Old Nov 28, 2008 | 07:59 AM
bswitz's Avatar
I can see the leak as soon as it gets hot. It's on top passenger side right next to the valve cover.
Old Nov 28, 2008 | 08:15 AM
bswitz's Avatar
If that's what it is how hard is it to replace? How much would it cost to have someone do if I don't have the time?
Old Nov 28, 2008 | 08:27 AM
salvy's Avatar
Do a search on ; intake gasket replacement, there you'll find pricing, tips on do it your self tips w/illustrations, ect..
Old Nov 28, 2008 | 08:49 AM
bswitz's Avatar
Thanks Salvy good info.
limited edition 1
Jan 27, 2023 11:07 AM
Speedysdad
Sep 16, 2013 12:36 AM
J.R. Clay
Mar 17, 2011 08:22 PM
LJ809
Apr 25, 2010 06:02 AM
01gmcjimmy
17
Jan 4, 2008 10:17 PM
